Drywall Costing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 11:06 AM   #1
weekend warrior
Hobb3s's Avatar
Drywall costing
Hello, I'm about to start a project to gut and redo one bathroom. I plan to do most of it myself. However I would like to get someone in to do the drywalling after i gut it down to the studs. I'm just looking for a general cost I should expect for this work to be done, to make sure I don't get hosed by a contractor. The room is 5 wide by 8 long with 8 foot ceilings, and I'm planning on leaving the ceiling intacted. I live in Ottawa, Ontario, in case location is relevant.
Thanks.
Hobb3s is offline   Reply With Quote
Old 04-02-2008, 11:23 AM   #2
In NH im seeing around .17 per square/ft of board (standard 1/2") and a high side of .80 a sq/ft on Install/finish. so at a 1.00 sq/ft all said and done(high side). With no doors and those dimensions thats a bit over 200. May be more for a small job...Im planning 19,000+ sq/ft of drywall and ive been getting Numbers a little under 1.00per sq/ft.
Hope this helps but my info my be off the wall as far as reliability goes, im sure some of the others may be more knowlegable!
Cheers,
Alex
NHERal is offline   Reply With Quote
Old 04-02-2008, 11:47 AM   #3
yummy mummy's Avatar
Rewards Points: 1,016
I live in Toronto, Ontario, and the cost around here to hang drywall is $2.00 per square foot, not including materials......
It is not a very big space, since you are doing most of it yourself, have you considered doing the drywall yourself?
It's not that difficult......
I just finished hanging drywall in two rooms, one 19 feet by 12 feet, and another 30 feet by 19 feet.
yummy mummy is offline   Reply With Quote
Old 04-02-2008, 12:04 PM   #4
weekend warrior
Hobb3s's Avatar
Thanks for the info, I have considered doing it myself, however I thought I would save my patience for all the tiling, and spend a little to get it done professionally.
$2 a sq ft.+materials, more than I expected, good to know though, thanks.
Old 04-02-2008, 12:17 PM   #5
This is really not a "per square foot" job. Need a little more info to give you an appropriate price (i.e. concrete board/tub/shower info), but your probably looking at 600-800 US dollars plus materials (ready for paint price). This is more of a job for a handyman. A drywall/finishing prof. usually wouldn't do this small of a job IMO.
jerryh3 is offline   Reply With Quote
Old 04-02-2008, 12:21 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
In MA, we are charging between $1 sf to $1.20 sf with materials. We may charge more. We are on the high side. Now, keep in mind, that is ballpark, for larger jobs.
A small bathroom, is generally NEVER priced by the sf, by anyone. The jobs are too small to price them that way. They are priced by the job itself.
My advice is to get some local quotes.
- Build Well -
Old 04-02-2008, 12:41 PM   #7
weekend warrior
Hobb3s's Avatar
Originally Posted by jerryh3 View Post
This is really not a "per square foot" job. Need a little more info to give you an appropriate price (i.e. concrete board/tub/shower info), but your probably looking at 600-800 US dollars plus materials.
I thought it might not be a a 'per sq ft' job because of the size of the room. You are correct, I do have a standard sized tub in the room where I would want concrete board surrounding, a window in the tub/shower and a door entering the room. I'll get some quotes no matter what, so I can make sure I have room in the budget. Thanks for the info.
Old 04-03-2008, 10:04 PM   #8
Rewards Points: 216
Please let us know what sort of quotes you receive and how you proceed.
Interesting subject --- DIY or call in a "pro".
orange is offline   Reply With Quote
Old 04-03-2008, 10:12 PM   #9
weekend warrior
Hobb3s's Avatar
Will do, I've got the first contractor coming to take a look on Monday.
Old 04-03-2008, 10:17 PM   #10
Rewards Points: 216
Good luck.
I'm iin Ottawa too. Nepean.
I'm planniing a new bathroom at the cottage later this year.
I like to DIY, but am looking forward to your project and comments.
I noted in one of your posts that you found this forum quite informative.
I totally agree - got questions answered very fast. I did some reno in living room -removed wall - installed pot lights. Am about to start hardwood floor and some ceramic tile.
Old 04-07-2008, 12:12 PM   #11
weekend warrior
Hobb3s's Avatar
The contractor stopped by, gave me a basic estimate and said he would draw up a quote. I got a 'guesstimate' so far of $700-900 (CDN) (including materials), which seems pretty reasonable. He also gave me a few more tips to make my demo easier.
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 12:40 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
