Drywall Corner Bead Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2007, 10:39 AM   #1
Drywall corner bead Question
I am in the process of finishing my basement. I am getting ready to hang the corner bead. I am using vinyl corner bead, my questions are regarding new areas that I haven't encountered before 1- butting two corner bead together for long runs, around the duct work, is there a trick to line them up? 2- Is regarding multiple outside corners, see picture, do you cut the corner beads into points and make the corner into a point. I am also attaching some pictures of one of the corners and test corners and but joint that I have done to see if I am on the correct track before the real thing.
Any help is greatly appreciated-Thanks
Cheers DK
Drywall corner bead Question-practice_corner.jpg   Drywall corner bead Question-practice_butjoint.jpg   Drywall corner bead Question-3-outside_corners.jpg
dk_99 is offline   Reply With Quote
Old 12-31-2007, 10:46 AM   #2
you are doing fine. problems beginners create is when they try to over lap and over secure corner bead. Don't go to heavy on the bed coats and this will look great.
Big Bob is offline   Reply With Quote
Old 12-31-2007, 02:07 PM   #3
When using metal corner bead, I always cut around a 6" piece and put it under where the two ends meet. This keeps the two pieces lined up and even. I don't know if you could do it with the vinyl, but I would at least try to put some kind of backer behind the two ends.
jerryh3 is offline   Reply With Quote
Old 12-31-2007, 04:02 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
That's a good suggestion that we utilize. Also, the pictures showing the edges of the vinyl corner bead that has the edges cut and the ends shaped to points: good form for a beginner!
I think a good lesson that can be learned from the OP is to:
1.) Do your research
2.) Ask questions
3.) Do test cuts or test pieces (Dry-fit), before attempting something new.
- Build Well -
Old 01-01-2008, 12:19 PM   #5
Power Gen/RS Engineer
Rewards Points: 566
I don't mean to hijack, but I have two simple questions with respect to attaching plastic corner bead (I will post separately if the group wishes):
1. What is the proper or best fastener to use? Can staples be used and if so, do they necessarily need to penetrate the underlying wood?
2. Since the mud has a lot of moisture in it, is it best to use a fastener that is galvanized or resists corrosion?
Thanks!
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 01-01-2008, 03:25 PM   #6
Staples and/or spray adhesive (for applying corner bead) may be used.
All staples are galvanized.
- Build Well -
Corner Bead for Drywall? sandyman720 Building & Construction 10 10-10-2007 10:17 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 08:20 AM
Drywall corner question dman60 Building & Construction 1 02-01-2006 11:52 AM
