Which Drywall Compound Should I Use? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-12-2007, 11:35 AM   #16
yummy mummy's Avatar
Rewards Points: 1,016
Originally Posted by BigJimmy View Post
I can't agree more. But then again, you seem like you're quite the DIYer so you should do just fine! BTW, is the background in your picture your latest project?
TTFN,
Jimmy
Yes, the project in the back is my basement when I had just started framing it, last year.
I like DIY projects as they are some what of an escape from what I normally do. (I have psych. degree).
And it's mindless work.
Hopefully, I will do ok with taping. I'm really not looking to get it perfect, but hopefully, presentable.
Thanks.
yummy mummy is offline   Reply With Quote
Old 11-12-2007, 04:00 PM   #17
Rewards Points: 5,336
The trick to taping is to use minimal amounts of compound. Because the more you put on, the more you will need to sand off. They now make a compound that minimizes dust in the air as you sand. It just falls to the ground. As a novice taper you might try the adhesive mesh tape. You can tape the whole room and then apply the compound. It has the added benifit of eliminating dry spots where you press too hard and squeeze out all the compound. When it dries, the paper pops out like a bubble.
Ron
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 05:59 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 08:22 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
