Drywall Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-17-2009, 02:25 AM   #1
Rewards Points: 91
drywall ceiling
Looking for some quick advice - I just hung 3 joists in my ceiling to cover a spot 44 inches wide. I thought I'd measured well, but, it turns out my last joist is 1/2 inch higher then the other two.
Is it okay to install drywall as is, I assume the drywall will bend sufficiently to cover 1/2 inch, but is it safe to do that, or am I placing too much pressure on the drywall that it might snap/crack later?
If unacceptable, would simply tacking a 1/2 strip of wood along the joist that's too high be the way to best resolve?
thanks in advance,
Matt
mmhendrie is offline   Reply With Quote
Old 03-17-2009, 06:17 AM   #2
Remodeling Contractor
furring the other joists will be fine. The drywall will not bend very well and will pop the nails eventually as well as look terrible.
Old 03-17-2009, 07:23 AM   #3
If you ever looked down the walls, ceilings of most houses with a LONG straight edge, you will see that they undulate in/out. You may never notice 1/2" over 32", but you can shim it out as needed and all will be fine.
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 10:11 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
