Old 11-25-2007, 07:47 PM   #1
jelly's Avatar
Drywall Butting issue
I have a 34" gap between two pieces of sheet rock which means one of the seams will not have two tapered edges. Please dont ask why I did it this way, my only answer is that I've never done this before. So this is what I am faced with...
Any advice/tips on butting two non tapered edges? Thank you.
jelly is offline   Reply With Quote
Old 11-25-2007, 08:04 PM   #2
Just my ideas, and I have that problem too.
1. Make sure the rough edge of the drywall paper doesn't protrude above the surface at the seam in question. You might wish to trim away about an 1/8 inch strip of the paper along the edge leaving the drywall core exposed.
2. Put on the mesh/paper strip and mud as if the seam was normal (with factory tapered edges butting).
3. After the first coat of mud dries, in the process of mudding the second coat, that seam will bulge out slightly but should be smoothable just as a normal seam is.
Old 11-27-2007, 10:07 AM   #3
waiting for spring
arichard21's Avatar
i would take down one of the pieces and put the 2 factory seams together, then get a 3rd piece to put on the end with a factory edge.
arichard21 is offline   Reply With Quote
Old 11-27-2007, 02:09 PM   #4
If your not good at tapping and worried about it take it down and get another peice for the couple bucks it will cost. You can tape the joints and never notice it, just takes a little more work when taping.
ponch37300 is offline   Reply With Quote
Old 11-28-2007, 06:58 PM   #5
Eibwen
Clean your seam between the boards and run a peice of paper tape as in normal taping.
Then work each side one at a time with wider taping knives and allow to dry between coats just as if you were taping a corner.
It will feather out the bulge where you wont see it.
Drywall finishing is perfect... Its one of those optical delusions....
Sammy is offline   Reply With Quote
Old 11-28-2007, 07:06 PM   #6
Cut the missing pieces and put it up. Tape the joints. The one with the nontapered edge will have a wider compound joint.
Not a big deal.
Ron
Old 11-28-2007, 07:06 PM   #7
You'll spend less time taking that board down and replacing it then you will trying to feather that edge on a ceiling.
Mike Finley is offline   Reply With Quote
Old 11-28-2007, 09:06 PM   #8
Remodeler
MinConst's Avatar
My thoughts exactly.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 11-30-2007, 03:34 PM   #9
I just hung drywall a few months ago for the first time. I had some help from a friend that does it on the side. I had several places where there were butt joints and had no problems with finishing them smooth. Some of the pros on here will tell you differently but all I did was butt the pieces tight, clean up any paper fuzzies, tape, and mud. I used a 6" knife to tape, then went to an 8" and then a 12" knife. No visible seems in the finished drywall.
By the way, there is no way to totally avoid butt joints anyway. I never understood why people make such a big deal about it. If you are hanging a ceiling for instance, you throw a sheet up there, and the next sheet is going to give you a butt joint where the untapered ( top and bottom ) edges of the two sheets meet. Its unavoidable. Just do your best and you can be proud of what you accomplished as a DIYer.
DIY4EVER is offline   Reply With Quote
Old 11-30-2007, 11:05 PM   #10
jelly's Avatar
Thanks for all the tips~ I ended up pulling the sheet down.
I agree DIY4EVER, butt joints are inevitable. I guess the fewer, the better.
Do I need a 12 knife? I have a 6 and an 8.
Generally speaking, what thickness should I be putting on the ceiling? Can I use 3/8 on exterior (load) and interior walls?
Old 12-02-2007, 01:26 PM   #11
12" knife will feather the edges out alot better than a 8". 5/8" rock on the ceiling and 1/2" on the walls, I have only used 3/8 a couple of times on remodels to get the thicknesses to match.
Old 12-02-2007, 01:31 PM   #12
Definitely get a 12 inch knife.
kgphoto is offline   Reply With Quote
Old 12-02-2007, 01:38 PM   #13
jelly said: "Generally speaking, what thickness should I be putting on the ceiling? Can I use 3/8 on exterior (load) and interior walls?"
3/8" sheetrock doesn't take much force to punch a hole in it. I use 5/8" for the walls and 1/2" for the ceiling.
I would use 1/2" minimum for the job.
Ron
Old 12-02-2007, 02:32 PM   #14
I prefer to use 5/8 always and 1/2 begrudgingly, and 3/8 only as an overlay or filler.
Old 12-02-2007, 06:09 PM   #15
You'll be just fine compounding a non tapered edge. Like stated above, you'll just have a little wider compound area than 2 butted joints. No biggie. Just think of the guys doing an entire house.... do you think they have tapered edges butted everytime? I don't think so. Don't fear it, tape it. The pro's usually use real long sheets that they run horizontal. So they're butting the 4' ends all the time, just less of them with the longer sheets.
GearHd6 is offline   Reply With Quote
Butting drywall together not even..... yummy mummy Building & Construction 12 10-23-2007 12:40 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
