Old 09-26-2007, 01:54 AM   #1
Drywall bull nose around a window
Does any one know how to cut and hang window bull nose bead properly?
dstolese is offline   Reply With Quote
Old 09-26-2007, 05:21 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You install it just like normal vinyl corner bead. Use spray adhesive and a T-50 hand stapler if necessary.
Measure, cut, install...coat and sand.
Coat the bead to the indentation line that is before the outside edge of the corner. You don't actually coat the rounded part of the bead, rather, it's left exposed. Use a sanding sponge when sanding it.
- Build Well -
Old 10-10-2007, 11:43 AM   #3
First you need to put the corners on (2-way bullnose corners) then cut the bead and you can nail it(metal) or staple it(vinyl) but make sure you duece them next to each other.
MudGirl is offline   Reply With Quote
Shrink Film Window Insulation miserlou General Discussion 10 11-24-2008 07:19 AM
Drywall Edges - bead or no? Ricky D Building & Construction 2 07-09-2007 08:52 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
I blew it on the mesurements.Vinyl window Doug Crf Remodeling 6 03-29-2007 11:06 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
