-   -   Drywall bull nose around a window (http://www.diychatroom.com/f19/drywall-bull-nose-around-window-11844/)
dstolese 09-26-2007 01:54 AM
Does any one know how to cut and hang window bull nose bead properly?
AtlanticWBConst. 09-26-2007 05:21 AM
You install it just like normal vinyl corner bead. Use spray adhesive and a T-50 hand stapler if necessary.
Measure, cut, install...coat and sand.
Coat the bead to the indentation line that is before the outside edge of the corner. You don't actually coat the rounded part of the bead, rather, it's left exposed. Use a sanding sponge when sanding it.
MudGirl 10-10-2007 11:43 AM
First you need to put the corners on (2-way bullnose corners) then cut the bead and you can nail it(metal) or staple it(vinyl) but make sure you duece them next to each other.
