Drywall Budget - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 04:48 PM   #1
Solutions (handyman)
Rewards Points: 364
Drywall budget
I am not asking for quoteds or estimates, however, I am working on a budget for drywalling and taping a summer cottage with about 5000 sq ft of covergae area. The drywall estimate estimates I have received are way out of wack. One is .22 sf and .32 sf for tape & mud. The second is 1.12 sf for boarding and 1.15 for taping and mud. Is there a standard rate that I should consider a fair range?
Thanks.
Mark Harvey is offline   Reply With Quote
Old 12-08-2011, 05:14 PM   #2
Rewards Points: 282
drywall quotes vary widely.
if you are going to be there, go the cheap route and keep an eye on them.
jcrack_corn is offline   Reply With Quote
Old 12-08-2011, 05:48 PM   #3
Rewards Points: 150
Apples to Oranges
I am wondering if the higher quote is materials and labor and the lower quote is labor only. Certainly that is a wide spread and requires more bids and the checking of references. I am not familiar with the material or labor rates in your area and I do not know your experience level with subcontractors, but just want to caution you to be specific; who is supplying materials, thickness of drywall, where it needs to be Type X, where bead is required, number of coats of joint compound in closets, number of coats in walk-in closets; if you have skylight tunnels, or walls that will be highlighted by the setting sun through sliding glass doors, that will need some extra attention you need to state it. With contractors (of which I was one for many years) you both need to state the obvious so that everyone has a clear understanding of expectations.
TheCamper is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 05:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
