Drywall Beads/trims - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2007, 11:33 AM   #1
Drywall beads/trims
Greetings all,
I'm hoping for some drywall help. I am creating a step-down racetrack like ceiling. I somehow need to finish the exposed edge of the drywall. Should I use L-bead/trim or J-bead/trim. With either of these trims do you have to finish the short leg or the edge covering the 1/2" width of the drywall with mud or are they paint ready?
Would I also need to caulk the seam between the ceiling and the edge of the bead/trim?
Thanks for any and all help!
agstaff is offline   Reply With Quote
Old 03-08-2007, 04:52 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
For what you want to accomplish.... use L-bead
http://amico-lath.com/drywall/mj_bead.htm
Neither trim's edge has to be finished. They are paint ready. However, realize that there are different width L and J bead for different thickness sheetrock. Make sure that you get the 1/2" if you are using 1/2" sheetrock.
That is up to you, dependant on the 'look' you are going for.
- Build Well -
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
