Drywall Bathroom Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2007, 04:46 PM   #1
Drywall bathroom ceiling
We have an old lathe and plaster house and I finally gave up on the cracks in the ceiling and drywalled it. Due to other work I won't be taping, mudding and priming for a few weeks. Should I be worried about humidity and the drywall? And if that is a problem, should i prime everything and then tape and mud later?
dave
docproteus is offline   Reply With Quote
Old 12-05-2007, 04:59 PM   #2
Rewards Points: 12
did you use green board or regular drywall?
ponch37300 is offline   Reply With Quote
Old 12-05-2007, 05:07 PM   #3
Regular drywall. The shower is fully enclosed, basically another room almost.
Old 01-09-2008, 09:37 PM   #4
no dont worry ur good and u dont need green board if u hung board over and water pipes sticky out the wall then u would or in the shower
rrisky is offline   Reply With Quote
Old 01-09-2008, 09:47 PM   #5
Well said.
jerryh3 is offline   Reply With Quote
Old 01-10-2008, 08:05 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
dave
Tape and coat as normal.
However: Make sure that you use a Mildew Resistant Primer and paint.
Make sure that you also have the proper ventilation (Exhaust fan) installed too.
Good Luck.
- Build Well -
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Bathroom Ceiling and Walls. Drywall ok? atilla137 Building & Construction 11 10-26-2006 04:32 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
