-   -   Drywall bathroom ceiling (http://www.diychatroom.com/f19/drywall-bathroom-ceiling-14117/)
docproteus 12-05-2007 04:46 PM
We have an old lathe and plaster house and I finally gave up on the cracks in the ceiling and drywalled it. Due to other work I won't be taping, mudding and priming for a few weeks. Should I be worried about humidity and the drywall? And if that is a problem, should i prime everything and then tape and mud later?
dave
ponch37300 12-05-2007 04:59 PM
did you use green board or regular drywall?
docproteus 12-05-2007 05:07 PM
Regular drywall. The shower is fully enclosed, basically another room almost.
rrisky 01-09-2008 09:37 PM
no dont worry ur good and u dont need green board if u hung board over and water pipes sticky out the wall then u would or in the shower
jerryh3 01-09-2008 09:47 PM
Well said.
AtlanticWBConst. 01-10-2008 08:05 AM
dave
Tape and coat as normal.
However: Make sure that you use a Mildew Resistant Primer and paint.
Make sure that you also have the proper ventilation (Exhaust fan) installed too.
Good Luck.
