Old 10-31-2009, 11:11 PM   #1
Arrow Drywall for bathroom
Folks I am a newbie here and need some urgent help. I love in Ontario Canada. I have a contractor who is finishing my basment for me. He is using regular drywall in the bathroom except for where the shower stall will have to go (he will use concrete backer board for the shower walls). I am not too conforatable with his approach. I think he should use green board or something similar for the bathroom walls. What do experts here say about this. Is anybody on the forum familiar with Ontario building code. Does the OBC say anything about the type of drywall that should be used in the batherooms.
Thanks a bunch in advance.
Geoff
geoffthemonk is offline   Reply With Quote
Old 10-31-2009, 11:49 PM   #2
Building codes guy, Mod
thekctermite's Avatar
I can't speak about Ontario's codes, but personally I wouldn't get all that concerned about not using greenboard in a bathroom. As you mentioned, the wet areas should always get backerboard and never sheetrock of any kind. If your bathroom is properly painted so water never reaches the drywall there should be no concerns. One of the biggest factors in breakdown of bathroom walls is lack of ventilation of the humidity...Use your bath fan. Greenboard has a mildew inhibitor, but isn't waterproof by any means. If it gets wet repeatedly it is shot. If you get mildew, that means you have moisture in the walls and greenboard won't help you.
In short, it wouldn't bug me.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 11-01-2009, 09:16 AM   #3
ccarlisle's Avatar
kct is right on...there's nothing in the codes that specifies blue- or greenboard in bathrooms - in fact many installers are going away from those products - as long as there is adequate ventilation.
ccarlisle is offline   Reply With Quote
Old 11-01-2009, 05:58 PM   #4
A free copy of an older Code Check for Canada pamphlet, page 26, no green board in wet areas , not over vapor retarder, not on ceilings with >12"o.c. framing......: http://rapidlibrary.com/index.php?q=...code+of+canada
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 11-01-2009, 07:58 PM   #5
I agree, greenboard is "water resistant" if it gets wet it will have the same affect as normal sheet rock, they also sell paints that are mildew/ mold resistant as well.
pbert is offline   Reply With Quote
More On This Topic
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
We're late now. This is my homasote. I got to, like I say, fill this gap in, well, all the way across, maybe even somewhat even with this. But, once I put my sheetrock each corner should meet and I'll show you how to do that as well. Well, just measuring... Read More »
The drywall you choose for your next home improvement project depends upon the room in which you are planning to work. Drywall, often referred to as wallboard, is available in different varieties, lengths and widths. Here's how to choose drywall for your... Read More »
How to Choose Drywall
How to Choose Drywall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about choosing drywall. There are a lot of different choices when you choose drywall. The drywall that I have chosen for this project is 5/8’s of an inch thick... Read More »
And that's how easy it is to cut sheet rock with a razor knife. Like I said, this is going to be a studio so if he wanted three pieces on there, I'd have put three pieces on there. But since he's satisfied with two. He's satisfied with it; I?m satisfied... Read More »
Problem Patching Large Drywall Hole FuLLTiLT Building & Construction 4 10-04-2009 01:09 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 12:48 PM
Ecorock (new green drywall product) Sir MixAlot Green Home Improvement 0 06-20-2009 10:40 AM
Good ways to run pegboard up to drywall? upthemaiden Building & Construction 1 03-09-2009 03:12 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
