Drywall And Basement Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 01:20 PM   #1
drywall and basement floor
hello, my nane is sonia;
i purchase a home and i have a finished basement but there is a gap between the drywall bottom and the basement floor. there was carpet there but i pull that up. what caulk do i use if any.
thanks for your help.
soniafel is offline   Reply With Quote
Old 12-27-2011, 02:45 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Are you not installing baseboard?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-27-2011, 02:51 PM   #3
Rewards Points: 12,868
Is alway suppost to be a gap. If not moisture wicks up the sheetrock.
As suggested just add baseboard.
Old 12-27-2011, 10:42 PM   #4
Registered User
Rewards Points: 4,924
The bottom plate to slab joint should be caulked or can foamed, as that is part of your exterior thermal barrier or air barrier;
http://publicecodes.citation.com/ico...002_par022.htm
Also the drywall to plate joint, as this would stop air from infiltrating there as well as stopping conditioned air from reaching the concrete wall; http://publicecodes.citation.com/ico...002_par021.htm
Part of the ADA, airtight drywall approach; http://www.buildingscience.com/documents/information-sheets/air-barriers-airtight-drywall-approach/
It can also help stop the “stack effect”, and degrading fiberglass insulation (by wetness or air movement) contributing to heat loss in those walls.
I recommend it for exterior walls, at least.
Gary
Moving basement washer to first floor issues mazeroth Plumbing 2 02-05-2011 10:10 AM
Question About Basement Floor Drains Mozart Plumbing 3 12-05-2010 03:19 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Drywall ceiling in basement using floor trusses ralphfravel Drywall & Plaster 10 04-03-2009 08:12 AM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
