Drywall Banjo - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2008, 09:44 PM   #1
Rewards Points: 12
drywall banjo
I am thinking about buying a banjo to do some taping. Is there a better brand out there? Anything to look for when buying one? Any tips on mixing the mud for these, does it need to be thinner? Thanks for any advice.
ponch37300 is offline   Reply With Quote
Old 03-16-2008, 10:15 PM   #2
www.handyguyspodcast.com
Use thinned mud
You should use a lightweight joint compound. If you buy the pre-mixed buckets, you will want to add about 4 cups of water per pail. See more info here: http://www.rd.com/17843/article.html
borninpa is offline   Reply With Quote
Old 03-17-2008, 09:36 PM   #3
Rewards Points: 12
Well i bought one today and didn't have very good luck with it! Found it to be easier to just spread the mud and then tape and smooth. Either they take some getting used to or something. It didn't spread the mud evenly on the tape. I had to hold it in just the right angle to get some mud on the tape. Maybe the mud was to thick? I thought i had it soupy enough. Any advice on using these? Thanks
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 08:30 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
