Drywall Adhesive, Use Or No ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 09:24 PM   #1
Rewards Points: 199
Drywall adhesive, use or no ?
Is it a good idea to use drywall adhesive on the ceiling drywall ?
On the wall drywall ?
I am trying to decide if I should go to the trouble of using drywall adhesive. It appears not to be used much around this area, if at all (Western Arkansas). The hardware and box stores don't even seem to carry it.
I was thinking about using it on my ceiling and exterior walls because they are constructed from rough cut lumber and the surface, or course, is not going to be nearly as even as if I had used milled lumber.
Someone told me to just use a few extra screws than typical and don't worry about it. But I was wondering if it greatly added to the strength of the attachment.
Under what conditions is it advisable to use drywall adhesive, and when is it pretty much just a waste of time and money ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 05-24-2011, 09:34 PM   #2
Framing Contractor
Rewards Points: 120
Use it on the walls only. It will be a pain to use on the ceiling and wont really do much.
sixeightten is offline   Reply With Quote
Old 05-24-2011, 09:39 PM   #3
Missouri Bound's Avatar
Using it on the walls will add lateral stability to the structure. It will allow you to use a few less screws. On the ceiling it usually isn't done.
Old 05-24-2011, 09:42 PM   #4
use it anywhere you can. you will have less screw pops later on. i knew one guy that would put drywall on the ceiling with 4 screws and glue it. he was one of the best drywall guys ive seen over 40 years. he even pulled string lines and shaved studs and joists down so the everything was flat.
The Following User Says Thank You to DannyT For This Useful Post:
tpolk (05-25-2011)
Old 05-25-2011, 07:40 AM   #5
I am agree with DannyT.. That willl be beneficiary for us and user too..
Petric is offline   Reply With Quote
Old 05-25-2011, 07:47 AM   #6
Framing Contractor
Rewards Points: 120
I have done a lot of drywall, and I have never seen anyone shave studs/joists. We were asked to glue a ceiling one time and it was a pain in the butt, and I don't think it was beneficial. Somebody please explain to me how 4 screws will hold up a 12' ceiling board.
Old 05-25-2011, 08:51 AM   #7
this guy was old old school and real particular. never saw anyone else like him ever tho and probably never will.
Old 05-25-2011, 09:31 AM   #8
if this is green rough lumber you need to let it air dry or it wont matter what you do
The older I get the better I was
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 01:48 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 04:58 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Adhesive remover from drywall bmt1970 Painting 3 05-13-2010 06:10 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
