Drywall Above Stairs Into Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 11:38 PM   #1
Drywall above stairs into basement
I'm looking for some ideas on how to drywall above the stairs going down to my basement. There is a 90deg turn to the right that happens over a few stairs. I'm thinking that I may have to put a strip of wood on the bottom of each stair so it would be flush with the backside board on the staircase and then drywall each individual step... any ideas?
mcjeffren is offline   Reply With Quote
Old 05-26-2011, 01:47 AM   #2
Rewards Points: 1,092
I'm confused, which is easy to do. What is the orientation of the pics? You mentioned 'rocking above the stairs, then on the back of the stairs. ??? Please enlighten.
Old 05-26-2011, 07:13 AM   #3
The picture shows the underside of the staircase that goes from the main level up to the second level so the light is near the ceiling, not the floor. In other words, if you were walking down to the basement and looked up, that's what you'd see.
Old 05-26-2011, 08:55 AM   #4
Rewards Points: 5,336
I'd clean up the framing by adding to it to eliminate all the angles. Then sheetrock it.
Ron
Tags
corner , drywall , stairs
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 09:33 AM
doug fir post for stairs on basement concrete chulett Carpentry 22 02-17-2011 08:56 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
