Old 04-10-2010, 10:10 AM   #1
drywall
Hi , I am drywalling a garage and i am going to run the drywall horizontal.
The sheets split the plug in about the middle. In other words i have to notch both sheets. Do i need extra support around the plug? and could this become a problem area. Thanks in advance. I have the 12 foot sheet already.
Thanks in advance.
seekers is offline   Reply With Quote
Old 04-10-2010, 10:24 AM   #2
Pro
Nostco's Avatar
drywall
Thanks in advance.
That doesn't make sense, you're not hanging the drywall properly.
Nostco is offline   Reply With Quote
Old 04-10-2010, 10:31 AM   #3
drywall
The plugs are in the middle of the wall and the bottom sheet comes up to the middle of the plug laid horzontil and the top sheet comes to the middle of the plugs from the cieling down.
Old 04-10-2010, 10:40 AM   #4
Pro
Nostco's Avatar
drywall
Oh ok, I'm sorry. I was imagining you meant the other way.
It wouldn't hurt to put some blocking at the seam. If it's a garage that is getting the standard treatment, I wouldn't put blocking. If it's going to be a finished space, I'd put in blocking. Takes all of 3 minutes to cut the wood and throw a couple of screws in.
Old 04-10-2010, 11:00 AM   #5
drywall
Hey thanks, I agree with you and appriciate the input.
The Following User Says Thank You to seekers For This Useful Post:
Nostco (04-10-2010)
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
