Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 12:54 PM   #1
Drywall
what is the easiest way to take it down
pmason02 is offline   Reply With Quote
Old 12-21-2011, 01:20 PM   #2
the Musigician
DangerMouse's Avatar
Ceiling or walls.... or both?
A hammer will make short work of it.
Messy job though, be prepared.
DM
Old 12-21-2011, 01:56 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
I'll just say "it's easier to put up than take it down"
as always, just my thoughts.
take what helps? ignore the rest!
coupe/Larry
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-21-2011, 02:34 PM   #4
Rewards Points: 13,260
Pop a hole it it with a hammer and start pulling.
Plastic bags will not hold it so plan on having to hand carry it and some way to haul it away, rent a dumpster, or a pickup with a tarp in in the bed of it will work.
Old 12-21-2011, 05:18 PM   #5
AGWhitehouse's Avatar
Start a hole with a hammer and pull away. Don't get too crazy pulling or you'll be taking it down a literal handfull at a time. Easy solid pressure will allow to you pull the nails/screws through and take off larger chunks at a time. A flat bar will be your best friend here. Once you get the hang of it, you can use the flat bar to pull down almost an entire 4x8 sheet in one piece...I've done it...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 12-21-2011, 05:22 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Jheeezh...do we have to do this again so soon?
Best Tools for Drywall Removal?
XXX
Old 12-21-2011, 09:12 PM   #7
Registered User
Rewards Points: 5,212
I use a 3' handled grub axe, the longer reach is way easier on the arms than a hammer handle. Just stick it and pull or lever off the joist/truss. After the 1/3 sheets are down, score them on the back on one side only with a utility knife to "roll" the pieces up on themselves, each cut being 2" wider to allow it to fold in to a compact bundle of still-attached to each other pieces. 4-5 fit in a heavy-duty plastic 32gal. garbage bag. Swing and hit the remaining screws going with the framing or it will make wood splinters (swinging perpendicular). They break flush with framing, swing the hammer away from you to direct the partial screw from your safety glasses-covered eyes. Takes one hit with a 14oz. hammer, very fast. Be sure the floor is covered and protected.
Gary
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
