Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 12:29 AM   #1
drywall
if you are doing a fire rated room do have to stagger the corned?
in a doble layer of sheet rock
nicoya is offline   Reply With Quote
Old 05-11-2011, 07:12 AM   #2
Rewards Points: 5,336
What is a "fire rated room"? Like a garage?
Were you trying to say, stagger the corners in a double layer of sheetrock?
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Willie T (05-11-2011)
Old 05-11-2011, 07:25 AM   #3
Rewards Points: 29
Typically seams do need to be staggered to meet a fire rating on a double layer installation.
Since people don't do fire wall installations without being required to I'm going to guess there is some sort of compliance issue.
In order to avoid problems with approval I suggest you go to the USG site. They have firewall construction details with UL approval. Build the wall to the most appropriate standard for your situation. That way you can provide documentation that you have met whatever needed requirements.
This isn't hard. The Specs just detail out seam, screw, taping installation.
Good luck
MarkusAIC is offline   Reply With Quote
Old 05-11-2011, 11:07 AM   #4
Drywall contractor
Rewards Points: 1,070
Good advice from MarkusAIC. I would stagger the corners......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-11-2011, 01:38 PM   #5
General Contractor
LakeTahoeDan's Avatar
typically for fire rating you would use 5/8" and you would have to just make sure it is it taped. and any penetrations ion the wall need to be properly sealed..ie. collars around pipes passing through the wall etc.
LakeTahoeDan is offline   Reply With Quote
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
