#1 |
Dryvit or Stucco over Existing Painted Brick
Hello,
I am buying a house that has painted brick and have found someone who will come out to "soda blast" the brick to it's original color and texture. I am afraid I will not like the color and the way it looks with the overall flow of the house. I am considering Dryvit or Stucco for the entire exterior. Does anyone have experience with this issue and is one preferred over the other. It appears that Dryvit can be easier to work with on corners, around windows or doors and such... Also. what should I expect to pay per sq. foot for either application on a one story, 1400 sq. ft. ranch home?? Thanks for the thoughts and help. |
#2 |
I was considering the dryvit system myself till I found out the cost and that they will not let you do it yourself.I have a 4400sqf home and the price I was given was 63,000 just for the dryvit.I also called the local dealer to see where I could get the material to do it myself and was told you must be factoy trained.So I an doind an acycrilic stuco wich should hold up better in our colder climate here
#3 |
How much should I expect to pay for the acrylic stucco?
#4 |
i found that dryvit is not good where there are children or high travlrd areas where people will be banging into it.....if u are considering doing dryvit i would perfere high density mesh to be used...cause if u get a crack and try to repair it it will not match up ....
#5 | |
Dryvit or Stucco over Existing Painted BrickQuote:
| Display Modes | |
| water leaking through brick chimney | quigleybmd | Concrete, Stone & Masonry | 45 | 02-26-2013 05:26 PM |
| Painting over painted exterior brick | kbrooke | Painting | 9 | 07-27-2009 10:27 PM |
| Stucco on interior cmu/fireplace | andys | Building & Construction | 1 | 06-24-2007 04:02 PM |
| How do I remove stucco from a ceiling painted with oil paint | labnotes | Painting | 4 | 01-09-2007 11:26 AM |
| Addition around existing brick chimney | Adenmoor | Building & Construction | 2 | 11-20-2004 11:37 PM |
