-   -   to drylok or not (http://www.diychatroom.com/f19/drylok-not-164462/)
Kab777 11-23-2012 04:36 PM
to drylok or not
my basement is dry but plan to finish it. should i drylok before finishing?
joecaption 11-23-2012 04:44 PM
It's not going to do any harm, but if you build and insulate the walls correctly it's also not going to do any good.
woodworkbykirk 11-23-2012 05:29 PM
if you dont have walls framed up yet dont drylok now.. drylok is meant to be allowed to move.. this means you shouldnt frame on top of it
Kab777 11-24-2012 10:41 AM
what type of insulation should be used? I assume something consisting of a moisture barrier.
woodworkbykirk 11-24-2012 04:05 PM
whatever you decide. you can use fibreglass. rigid foam or hire a spray foam company to come in
joecaption 11-24-2012 05:52 PM
There has to be at least 1000 post on this one subject. Go up to search and check it out.
Gary in WA 11-25-2012 12:58 AM
Where are you located?
Gary
stadry 11-25-2012 07:19 AM
location isn't as important imho as performing a vapor transmission test PRIOR to doing anything,,, in my experience, ' drylock ' type-materials work best in brochures,,, xypex is a much better treatment
Gary in WA 11-25-2012 06:47 PM
Location is very important figuring insulation/vapor barrier requirements, I think. Perhaps you missed Post #4... been there, done that, LOL.
Most basements appear dry or wet. Some "dry" ones look that way due to room air currents dissipating moisture as it wets surfaces. One needs to keep interior conditioned air from reaching the colder concrete wall or rim joists to deposit moisture there; http://www.buildingscience.com/docum...ts?full_view=1
Gary
stadry 11-26-2012 07:11 AM
hot always runs to cold hence the moisture test suggestion
