Drylok, Good Idea Or Not? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 07:08 AM   #1
Drylok, good idea or not?
I have an older house ,built in 72, and during heavy rain the basement leaks. We are in the process of selling the home and the basement poses concern to future buyers. It's not a finished basement, and using a dehumidifier it dry's in less than a day. I've heard pro's and con's with using drylok and just don't know what to do. We have had estimates on waterproofing and most say do a french drain, but the cost is so much. Any suggestions would be greatly appreciated as we thought about applying the drylok soon. Thanks
bk626 is offline   Reply With Quote
Old 06-29-2011, 08:22 AM   #2
Work Hard, Play Harder
Rewards Points: 212
You can do the drylok, and then the new owners can be screwed. Guess what is peeling off my basement walls as I struggle to come up with the money, patience and time to deal with our basement water problem? Oh; you guessed it - Drylok! With the bitter new homeowner in me out of the way....
I suggest you disclose the problem regardless of how you fix it, and provide the paperwork on how you had it fixed. Drylok isn't a fix in my eyes, it is a cover-up. Since you have just light moisture; You could assess the grading and gutters and fix any deficiencies there; which may alleviate the problem or in some cases eliminate it. If there is a gutter leaking bad or absent; or a portion of the house has bad grading; that water could be collecting around the foundation.
Sorry you have water in the basement; it really makes you pull your hair out...
EDIT: I believe it is called "inward drying"; as the foundation gets wet it needs to dry inwards, drylok locks the water in the foundation. Here is a great read:
http://www.buildingscience.com/docum...ctypes/digests
coderguy is offline   Reply With Quote
Old 06-29-2011, 08:33 AM   #3
Thanks, water in the basement wasn't that big of deal while we just lived there. We dealt with it and moved on, its an unfinished basement we just use to store items and a truck. Now that we have it for sale.... huge frustration. I would think having a basement would be a plus, but not so much anymore.
I've heard drylok can cause more problems than it can help. The water has to go somewhere, and if it can't come out, where's it going to go? We also did a pre-inspection, and the inspector said he wouldn't paint the walls since that's a big sign you're hiding something. I think we may work on the gutters (draining) and maybe do some minor grading to slope away from the house first.
I appreciate the feedback!! and the link!
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 01:01 PM
Sponging Wet sheetrock mud? Good Idea or No? Scotsman General DIY Discussions 5 11-10-2009 02:14 PM
To Drylok or not to Drylok 68tele Painting 4 11-02-2009 07:40 AM
Is using Luan to overlay soffit a good idea? ConstantChange Roofing/Siding 17 10-19-2009 08:48 AM
$10 per sq. ft..... good deal? KUIPORNG Landscaping & Lawn Care 3 04-21-2008 02:59 PM
