Drying Time For Mortor Before Grout - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2011, 10:53 PM   #1
Old Hand
Drying time for mortor before grout
I've now read 3 different recommendations in regard to how long to wait after putting up tile (tub/shower surround) before I put in the grout. I've already completed a number of bathrooms but am always interested in the current thoughts on the process. I am using "normal" grout with no additives.
iliketowork is offline   Reply With Quote
Old 09-23-2011, 11:28 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
Depending on how warm it is in the space, and humidity, it could be done same day. I would at least wait one day to do the grout, so that you give the mortar time to dry, since it will still be "green" if you attempt to grout the same day you put it down.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
iliketowork (09-24-2011)
Old 09-24-2011, 08:02 AM   #3
Rewards Points: 5,332
You need to let the thinset, "set", before you grout, otherwise the tiles will move.
I grout the next day.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Tags
grout
What did I do wrong the first time - I don't want repeats Snav General DIY Discussions 13 01-25-2010 02:26 PM
botched grout/tile job hello1 Tiling, ceramics, marble 10 09-29-2009 04:48 PM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 09:51 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 07:49 PM
