Dryer Vents (stacked) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 06:56 PM   #1
Rewards Points: 14
Dryer vents (stacked)
I can't seem to find an answer for what I want to do. Here it is: I'm adding a second washer/dyer. I plan on running a second dryer vent for the new dryer. However, space is limited and I need to run the vent over the other vent (on top of each other) So, at the exterior of the garage one vent will be above the other, maybe 1" apart. Is this an issue? Also, inside the garage the new vent line will have a slight incline when it needs to go up and over the existing vent line. Is this a problem for the lint? I am worried it will get caught in the incline.
Sent from my iPhone using DIY Forum
ofcjosh is offline   Reply With Quote
Old 01-05-2013, 01:05 AM   #2
Rewards Points: 13,300
What type siding do you have?
Your going to need more room between them to make room for the fin that attaches the outside part of the vents.
Old 01-05-2013, 07:50 AM   #3
Rewards Points: 3,130
You do not want the vent to incline toward the dryer, especially in a garage. Moisture will condense in the line and run back into the dryer. Any incline should be toward the outside.
Old 01-05-2013, 09:09 AM   #4
Rewards Points: 14
Joe- it's in a garage and I'm going through the cement block wall. I planned enough room between the two so the outside plastic piece will be an inch above the other one.
I planned for the vents to incline out of the garage, just slightly so ill stick with that. i just wasn't sure if it was right so thanks for the information!
Old 01-05-2013, 09:23 AM   #5
Rewards Points: 1,216
Go ahead and install them as described shouldn't be any problem.
just make sure you don't use screws on the pipe anywhere use tape. Make sure all the pipes are installed properly with the flow of exhaust air to the outside.
Pipes from the dryer crimped ends in the uncrimped end all the way out.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 01-05-2013, 09:37 AM   #6
Rewards Points: 14
Thank you very much! I love the info on this site.
Old 01-05-2013, 10:12 AM   #7
Yes I was actually looking for the same info loving this site so far
JConoverVegas is offline   Reply With Quote
Old 01-05-2013, 07:23 PM   #8
Rewards Points: 528
Actually I prefer the small screws to tape because the pipes are easier to break apart with screws. Maybe duct tape would be easier but I had used foil tape and had to cut the joints for cleaning.
Cleaning the dryer vent pipe is necessary evil. No configuration will make it self cleaning. Clogged pipe is not just about longer drying time, etc. It can damage some kind of sensor in the dryer. Sorry I can't remember what, but if you are curious, that information should be in repairclinic.com.
edit: BTW, I forget myself. Someone from the appliance forum should be able to specify that too.
carpdad is offline   Reply With Quote
Old 01-06-2013, 08:00 AM   #9
NEVER USE SCREWS ON DRYER VENTS THE LINT WILL CATCH ON THEM AND CAUSE A FIRE..........
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 10:48 PM
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 05:32 PM
how to avoid condensation in exterior wall when enclosing washer/dryer pemn Remodeling 6 12-01-2010 03:35 PM
Ridge vents and roof vents jerry1967 Roofing/Siding 4 06-07-2010 06:40 PM
dryer vents and varmints. afabco Plumbing 1 08-04-2008 04:31 PM
