Dryer Vent In Middle Of Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 12:38 PM   #1
Dryer vent in middle of wall?
I have a downstairs laundry room and the dryer vent is simply a hole in the floor with a short duct that goes under the floor to a hole in the rim board.
I need to attach a deck ledger along the rim board of the house so I want to know if I can move the vent up a few feet so it is in the middle of the wall? Is that usually allowed by code?
When the original deck was built 25 years ago they just cut a gap for the vent and of course it rotted the deck in that area
kwerk is offline   Reply With Quote
Old 08-21-2010, 01:32 AM   #2
Rewards Points: 956
i would say yes since heat travels upwards anyways
federer is offline   Reply With Quote
Old 08-21-2010, 03:15 PM   #3
Registered User
Rewards Points: 5,516
Sure, just nail a cedar block on the sheathing underneath the lap siding.I would replace your type "B" door with a type"A" to be 45% more efficient. The louvered ones tend to collect lint at the door through pins. http://www.appliance411.com/faq/dryer-vent-length.shtml
Be safe, Gary
Using 4" PVC for dryer vent Thurman Appliances 10 01-10-2016 09:28 AM
help with dryer. vent size problem? semidevil Appliances 9 09-06-2013 03:10 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Install dryer duct booster or find a shorter vent route? dinosaur1 Appliances 7 12-02-2009 12:26 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
