Dryer vent backdraft damper
I would run straight smooth metal pipe, with 45* elbows (unless close to the max. on elbow deductions) right through the crawl door/plywood. Oversize the hole, add metal tin pieces (overlapping at center circle cutout), use Type A hood with aluminum foil tape at all joints, including each individual elbow. If a gas exhaust also, follow codes sited- 3' from openings, etc. Don't forget to use stainless steel flex hoses on the water supply to the clothes washer (no burst).
Be safe, Gary
Clothes taking longer to dry?
