Dryer Vent - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-03-2010, 09:02 AM   #1
jsp
Dryer vent
Laundry room wall is under our stairs that leads to the second floor of our home and the dryer vent runs under the stairs to the outside- Should we be concerned that cold air is going to come in through the vent and cause pipes to freeze
jsp is offline   Reply With Quote
Old 11-03-2010, 02:55 PM   #2
Registered User
Rewards Points: 526
There should be a flapper damper on the termination hood already. I would use a "Type A" for much more clear door opening: http://www.appliance411.com/faq/dryer-vent-length.shtml
Insulate it and use smooth wall ducting, tape on joints, no screws: http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf
Gary
Dryer vent problem carguy4sp General DIY Discussions 7 11-29-2010 08:26 AM
Flat dryer vent code??? duct Chemist1961 Appliances 3 10-24-2010 04:49 PM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 10:39 PM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
