Which Dryer Duct Construction Choice? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 01:38 PM   #1
Rewards Points: 206
Question
Which dryer duct construction choice?
Getting ready to put 4" ducting through the crawl space from the dryer to the outside.
Total length of the run will be about 14' with one 8' straight section and one 3' or 4' straight section. I will use strapping and metal tape to insure that no sagging or leaks occurs. There will be four elbows. Should be possible to go downhill all the way.
Here are my material choices:
  • Aluminum: Can't find long sections of rigid aluminum ducting. Best available locally is 2' straight sections. Can also get adjustable elbows in aluminum.
  • Galvanized: 8' sections of rigid galvanized and adjustable/fixed galvanized elbows are available.
I want long term, trouble free service.
Which of these two choices is better?
John_W is offline   Reply With Quote
Old 07-01-2011, 03:58 PM   #2
Thread killer
Rewards Points: 272
Have you considered using 4" pvc pipe?
Canucker is offline   Reply With Quote
Old 07-01-2011, 04:07 PM   #3
Rewards Points: 206
No. I read that lint gets a case of static cling in PVC.
Old 07-01-2011, 04:11 PM   #4
i'd go with the galvanized and insulate it to stop condensation.
Old 07-01-2011, 04:21 PM   #5
Thread killer
Rewards Points: 272
Good point, completely forgot about the static buildup.
Old 07-01-2011, 04:55 PM   #6
AGWhitehouse's Avatar
I'd go with the galvanized as well. With the four corners, try to give yourself a cleanout so you can get in there. Corners will slow down the exhausting air and provide places for lint build-up. Also, since your in a crawl space, be sure to pitch the vent pipe slightly to allow any condensing moisture to drain away.
AGWhitehouse is offline   Reply With Quote
Old 07-01-2011, 06:00 PM   #7
Rewards Points: 206
I was wrong about the number of elbows. Now I think there will be two 90 degree turns an one 45 degree turn. I will try to make each 90 degree turn 'gradual' rather than sharp.
How do you make a cleanout?
Old 07-02-2011, 08:36 AM   #8
ccarlisle's Avatar
The latest IRC (International Residential code) specifies galvanised for new construction. A bit more tricky to work with, as the seams have to be made in situ. But your choice really.
For only 14', I'd use screws and foil tape to secure the sections. Easy to take apart if you really have to...If you really need a cleanout, kits are available that allow you access from the outside vent hood. And for that distance (which is average-to-short), cleanouts are very optional. I haven't seen one in that distance and haven't found a piece that wouldn't impede the flow more than any good it may do.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 07-02-2011, 09:02 AM   #9
Screws on a dryer ducting? Foil tape only, otherwise you'll have a pretty quick buildup of lint.
VIPlumber is offline   Reply With Quote
Old 07-02-2011, 09:04 AM   #10
Rewards Points: 206
Thanks for the IRC code info.
It's sounding like galvanized is the way to go. I will use foil tape along all the seams and at all the junctions. Probably not use screws as they catch lint.
If the turns are gentle enough, and at 14', it should be possible to clean out the duct from one end or the other.
Old 07-02-2011, 10:44 AM   #11
General Contractor
Screws penetrating dryer ducts are not allowed here either.
dsconstructs is offline   Reply With Quote
Old 07-02-2011, 07:57 PM   #12
Registered User
Rewards Points: 5,460
2009 IRC specifies metal ducting, aluminum or galvanized, no screws or screens, click on the “next section” to see all sub-sections: http://publicecodes.citation.com/ico...002_par004.htm
The termination hood is important, Type “A” being 50% better for air-flow than type “B”: http://www.appliance411.com/faq/dryer-vent-length.shtml
Gary
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 06:18 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
pex and dryer duct NailedIt Plumbing 3 12-12-2009 12:21 AM
Install dryer duct booster or find a shorter vent route? dinosaur1 Appliances 7 12-02-2009 12:26 AM
