Dryer Duct Angle To Outside Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 10:06 AM   #1
Rewards Points: 202
Question
Dryer duct angle to outside wall?
Putting a duct in to exhaust an electric dryer through the crawl to the outside.
The total length of the 4" galvanized duct, from where it enters the crawl space to where it exits the outside wall, will be about 10 to 12 feet, with one sharp 45 degree turn and two more gradual 90 degree turns.
At the outside wall, is it better to use a straight piece of duct, with a slight downward slope all the way out through the outer wall - or - put an adjustable 'corner' section at the hole to the outside and feed it with a shorter but more downwardly sloped straight piece?
The hole to the outside will be in the same location, either way. The straight section will be about 6 feet long. The total drop on that 6 foot length will be about 3 inches.
My guess is straight all the way to avoid extra lint-trapping by the adjustable corner at the end that goes through the outside wall.
John_W is offline   Reply With Quote
Duct in exterior wall kbennett HVAC 1 12-12-2010 08:22 PM
how to avoid condensation in exterior wall when enclosing washer/dryer pemn Remodeling 6 12-01-2010 03:35 PM
Backdraft Damper For Dryer Duct tima2381 Appliances 1 06-07-2010 04:24 AM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 11:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
