Dry Wall Mudding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2009, 06:42 PM   #1
Rewards Points: 18
Unhappy
Dry Wall mudding
I need advice
My contractor is finishing my basement
He installed the 2X4s and the dry wall. He is in the process of taping & mudding with a the all purpose mix ( compound) that comes in the green caps 5 galon bucket . In the morning we noticed alot of mouisture and water droplets on the windows in the basement . We hear a ticking noise coming from the furnace . It this an issue or a normal outgassing of the compound...Any advice will help??...Thanks
mmohanna is offline   Reply With Quote
Old 11-21-2009, 07:23 PM   #2
DIY staff
Rewards Points: 7,174
Quite normal--High humidity---The clicking from the furnace is probably an electric air filter.
Remind the contractor to cover the return air intakes during the sanding.(Or turn off the furnace while sanding)--MIKE--
Old 11-21-2009, 07:29 PM   #3
Rewards Points: 18
Thank You
Should we keep the basement window open for ventilation during the night?
By the way we opened new vents in the basement for heating should we also add a return ?...Where does it go???.Thanks alot
Old 11-21-2009, 07:34 PM   #4
DIY staff
You could open a window-However if the heat is on ,the open window should not be needed.
A vent cover cut into the furnace room wall usually is all that is needed.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
