Dry Wall Metal Beading Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2008, 09:51 PM   #1
dry wall metal beading repair
I have an older house and I've notice that the metal corner beading is pulling away from the wall. I was wondering if it is better to take the beading off and start over, or should just screw it in and put dry wall compound over it? I have read that some people put dry wall tape over the edges of the beading and then mud over the tape to prevent it from pulling away from the wall?
sluggermike is offline   Reply With Quote
Old 02-16-2008, 11:25 PM   #2
Remodeler
MinConst's Avatar
Pictures would help here. Repairing a piece of bead could be tuff to blend. It depends on the amount of damage what would be the best way.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 02-17-2008, 09:26 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Try pushing it back and re-screwing it, then re-taping and re-coating. Do this with one corner and give it a little time to see if it stays in place, before doing the others.
This would be the normal solution in most situations.
- Build Well -
Old 02-17-2008, 09:39 AM   #4
remodeling pro
Taping over the bead will not stop it from pulling away from the wall, only hide the problem short term. Assumming you have a little drywall skill.... the best thing to do is use a putty knife and hammer to gently crack all of the mud off of the length of the bead, this should reveal an indendtation about 1 1/2 inches wide up the corner on both sides of the bead. My suspicion is that you will not see any fasteners holding the bead on, it was most likely hung using a clinching tool only. Fasten the bead with some drywall nails, being carefull not to hit the corner of the bead and kink it, or drive them too far and cause the bead to bend. The nail heads are flat and much easier to mud over than a screw. Then remud the corner and finish it. Do not try to apply too much mud at one time or it will crack when it dries, corner beads are a three coat mud application, even for the pros.
troubleseeker is offline   Reply With Quote
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
