Old 04-04-2009, 09:58 AM   #1
Dry Wall Bathroom
I'm putting up new dry wall on the ceiling of our bathroom this weekend and I'm not sure what to use. I read I an earlier posting that it should be a special kind of dry wall because of the dampness and a special thickness if the rafters are 24". Sorry to duplicate someone elses question but I can't find the posting
MikeyP is offline   Reply With Quote
Old 04-04-2009, 12:06 PM   #2
Remodeling Contractor
Dry Wall Bathroom
You need to have ventilation in the bathroom for any type of drywall to last. You should use 5/8" drywall on the ceilings with 24" OC spacing. See if you can find mold free drywall like denshield. Technically 1/2" from some manufactures can be used for this spacing. But 1/2" green or purple drywall is not as still and cannot be used with this spacing. You will need to add furring strips perpendicular to the ceiling joists and set them at 12" OC for these type of drywall panels.
Old 04-04-2009, 12:15 PM   #3
Dry Wall Bathroom
Here's a link to others:
http://www.toolbase.org/Technology-I...t-gypsum-panel
Ron
Old 04-04-2009, 12:21 PM   #4
Residential Contractor
Dry Wall Bathroom
Mikey,
I have made the switch in all of my bath remodels to DenArmor + instead of Denshield. Although it does not have the waterproof qualities, it is great for mold and mildew, and is rated better for Sag resistance. It also has recessed edges like reg drywall, so it is easier to finish for paint
Trace
Tracymc is offline   Reply With Quote
Tile in Shower and on Wall of Bathroom jwhiteuwc General Discussion 2 02-02-2009 09:21 PM
Minimum wall thickness for electrical dc4nomore Electrical 10 10-10-2008 09:00 PM
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 05:32 PM
retiling bathroom wall J187 Remodeling 1 03-02-2007 11:03 AM
Bathroom Wall Fix PlankflooR Remodeling 4 01-28-2007 11:26 PM
