Dry Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-29-2008, 12:55 PM   #1
dry wall
Hi I have to do some dry wall how to install which way stand it up or lay it down and why would you do it lay down or stand it small walls maybe . say if you lay down a sheet of drywall and the wall is long then the drywall how you make a joint two sq joint not good for mud right top and bottom are sq right need help thanks
doo-man23@comcast.net is offline   Reply With Quote
Old 09-29-2008, 01:22 PM   #2
the Musigician
DangerMouse's Avatar
this site may help http://www.drywallschool.com/protips.htm
DM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
