Dry Pack Mortar Bed Slope In Shower - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 09:30 PM   #1
Dry Pack Mortar Bed Slope in Shower
I just put in a dry mortar bed in a 58"x60" shower. The drain is at 28" centered from the walls and I have a 3/4" slope from the side walls.
Is this correct or should the 1/4" every foot be from the corners?
If it isn't correct, what can I do other than tear it out and start over?
The pic is a little blurry but hopefully it will work.
kntry is offline   Reply With Quote
Old 08-30-2009, 09:52 PM   #2
Rewards Points: 5,336
Is that a Kerdi drain in the floor?
Ron
Old 08-31-2009, 07:23 AM   #3
Yes.
The depth at the outer ring is 1 1/4" and 2" at the wall.
Old 08-31-2009, 10:29 AM   #4
Pour some water in there and see how it works. It should be tested anyway.
Mop in Hand is offline   Reply With Quote
Old 08-31-2009, 10:40 AM   #5
I asked that question and was told that if the mortar bed was done correctly, the water would just go through the mortar.
I may try putting a very thin sheet of plastic in there and see if it drains.
Old 08-31-2009, 04:24 PM   #6
It needs the membrane system installed prior to testing.
The slope you have is fine.
Ron
Old 08-31-2009, 06:59 PM   #7
Thank you. That really puts my mind at ease.
For future reference, should the 1/4" per foot rule be measured from the corner or from the side walls?
Old 08-31-2009, 08:07 PM   #8
Registered User
Termite's Avatar
Just use a small torpedo level ALL OVER THE PLACE. Make sure that you've got pitch to the drain at all locations and don't focus so hard on 1/4" per foot (although that's probably ideal) or corners versus walls. Measuring can get you in trouble in my opinion, but a level bubble doesn't lie. Sometimes a longer straight edge helps you identify low spots or flat spots that won't drain well or will hold water after use.
New tiled shower won't drain; mortar in drain. catitudes Plumbing 5 03-29-2009 01:08 PM
Pre slope question on shower floor - did I do it wrong? maestro300 Flooring 2 02-20-2009 02:44 AM
shower pan slope 2picky Remodeling 3 11-15-2008 04:05 PM
Shower floor slope Not Sure Building & Construction 11 06-10-2008 11:12 AM
