Dry-Lok Basement Blocks Before Drywall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 05:02 AM   #1
Rewards Points: 43
Dry-Lok basement blocks before drywall?
Hello,
I plan on drywalling my basement. It is actually a lower level of a split, and is completely dry. No water issues. I'm down to the bare cinder blocks. They had been previously painted once before by one of the previous owners. They were then covered up with that nasty faux wood paneling.
I was thinking painting the walls with Dry-Lok before I glue down 2" foam. However with the walls being previously painted, I'd have to some how remove the paint from the blocks before applying the Dry-Lok.
I'm just seeing if anybody has any thoughts on this? Is it necessary? If so what is the best way to remove the paint from the blocks? Thank you for reading and any suggestions.
jobblyman is offline   Reply With Quote
Old 11-20-2010, 07:21 AM   #2
Rewards Points: 4,640
nevertheless, i'd do a moisture test 1st to be more certain there's no wtr issues,,, home bldrs only warrant dry bsmts for 1 yr as they know it generally takes longer for the problems to appear.
why do you think you need to remove the existing paint ?
Old 11-20-2010, 09:26 AM   #3
Rewards Points: 43
I have taped the piece of plastic to the wall, left it for a few days. It was dry. After days of non stop rain the level smells fresh, no must. I've been here two years and inspect all the time... My house is also 44 years old, so warranty issues here.
Old 11-20-2010, 09:27 AM   #4
Rewards Points: 43
oh and you need to remove the old paint before you can paint with Dry-Lok...
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 04:15 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Finishing old basement force4ormore Building & Construction 1 12-29-2008 02:48 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
