Driveway Widening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 06:02 PM   #1
driveway widening
hello all 1st time here, dilemma is driveway end ( between curb and sidewalk needs to be widened by about 3 ft. the curb is raised on 1 side about 1 ft, where do i start thank you all in advance for any and all advice
DT
dtdone is offline   Reply With Quote
Old 11-20-2010, 06:31 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,088
Ayuh,... I'm guessin' your talkin' Concrete,..??
A jackhammer/ Large hammerdrill will bust out what needs bustin' out...
A gas handheld demosaw is great for trimming, 'n angle cuts...
Cut/ bust out the curb to below finish grade by a few inches so it can be capped with the new apron pour...
After you dig out whatevers in the expansion area now,...
Form it up, 'n pour the new driveway apron...
Bondo is online now   Reply With Quote
Old 11-21-2010, 06:42 AM   #3
Concrete & Masonry
Rewards Points: 548
You start with your local governing body, because the odds are the section of the driveway (the approach) you're looking to add on to is within the public right-of-way. If in The ROW, there are typically clear cut standards, specifications, and dimensions that need to be followed. Many times, a bond needs to be held as well.
jomama45 is offline   Reply With Quote
Driveway prep Ultrarunner2017 Building & Construction 2 10-11-2009 11:51 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Bury my old driveway problems? kingcire Landscaping & Lawn Care 3 08-10-2009 04:47 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 07:07 PM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 05:19 PM
