Driveway Materials - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 09:09 AM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Driveway materials
What kind of options do I have for a driveway? I don't really want concrete or asphalt.... It's gravel now, and developing potholes. I'd like to put something nicer in there, but not sure what material I can use...
Journeyman Plumber
Old 06-07-2010, 09:25 AM   #2
Concrete, gravel, blacktop are the 3 tops
Stamped & stained concrete looks much better
They can also stamp & stain blacktop - it won't look like blacktop
Around here they use crushed shells too - Cape Cod - rough on the feet
The only other choice I can think of is pavers
Which need a good base
I'll probably go with just plain blacktop
Easier to shovel/melt snow
Old 06-07-2010, 12:48 PM   #3
Rewards Points: 502
there is always crushed white stone for a fancy looking gravel
forresth is offline   Reply With Quote
Old 06-07-2010, 04:50 PM   #4
Rewards Points: 4,726
google up ' grasspave ' + ' pervious concrete '
Old 06-07-2010, 05:56 PM   #5
Rewards Points: 5,336
Pavers.
Ron
Old 06-07-2010, 07:39 PM   #6
kwikfishron's Avatar
Rewards Points: 760
I’ve seen some really cool driveway to entry pavers systems.
DIY?
Maybe, probably not.
kwikfishron is online now   Reply With Quote
Old 06-07-2010, 08:59 PM   #7
Rewards Points: 286
I've contemplated having mine paved many times. The only advantage for me would be easier snow removal. Pavement is more expensive maintanence than the stone that is in there. Potholes, I can fix pretty cheap. True they come back. Construction sand under the stones seems to get good milage. Blacktop would be 4-5000 then the annual sealing and periodic resurfacing.
Jim F is offline   Reply With Quote
Old 06-07-2010, 10:44 PM   #8
Rewards Points: 1,016
I have a DG driveway and parking ramp to my workshop - has worked out well over the past 5 years it's been in use.
http://www.landscape-design-advice.c...d-granite.html
Old 06-08-2010, 05:42 AM   #9
building roads/runways/driveways in frost areas is much different than down here,,, $ is usually the deciding factor.
Driveway prep Ultrarunner2017 Building & Construction 2 10-11-2009 11:51 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Bury my old driveway problems? kingcire Landscaping & Lawn Care 3 08-10-2009 04:47 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 07:07 PM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 05:19 PM
