Driveway Gate Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 07:56 PM   #1
Driveway gate post
What is the standard gauge for a 4x4 driveway gate post for a 6x8 gate?
Macaroons is offline   Reply With Quote
Old 03-31-2013, 08:01 PM   #2
concretemasonry's Avatar
Rewards Points: 2,626
Heavy gauge with a good depth and a lot of concrete. - They take a beating and any tilting is very obvious and may not be improved enough by adjusting.
Dick
concretemasonry is online now   Reply With Quote
Old 03-31-2013, 09:37 PM   #3
Roofmaster
Rewards Points: 2,210
I would say at least 11 gage, a serious footing, and two posts with (2) 5 foot wide gates. 8 feet is too narrow, IMHO, but Im not a gate builder.
Old 03-31-2013, 10:54 PM   #4
Rewards Points: 1,016
I made my driveway gate nearly 13' wide - glad I did. 8' is not a lot of clearance. Posts are heaviest gauge, planted deep and well set in concrete.
____________
Vince
Old 04-01-2013, 09:37 AM   #5
Roofmaster
Can you put a number on "Heaviest"? That may help the OP. I just wish I had enough property to need a gate !!!!
Old 04-01-2013, 11:59 AM   #6
I went to a local fence supplier - looked through what they had and recommended and selected the heaviest/best they had. Unfortunately, I don't recall specifics.
I set my posts, then measured the distance between - and went back to the fence supplier and had them build the gates to fit the actual space.
____________
Vince
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 09:56 AM
Beam build, joint not over post WillK Building & Construction 8 01-03-2012 09:31 AM
Craftsmen style driveway gate bigb6456 Carpentry 12 05-19-2009 12:02 PM
Driveway Gate - swing open -vs- slide sideways MrLinux General DIY Discussions 1 10-30-2008 03:13 PM
