Driveway Foundation Seal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2007, 12:41 PM   #1
Driveway foundation seal
I have a driveway that meets up diectly to the foundation of my house. There is a small gap of a 1/4 inch between the driveway and foundation. I have been using that foam sealant between the two to prevent water from potentially leaking between the driveway and foundation. Is this even necessary and if so, is there somethign else I should be using? I have to apply the foam sealant nearly every year.
Thanks,Joel
bigboyjoel is offline   Reply With Quote
Old 10-06-2007, 10:23 PM   #2
Is the gap getting larger?
Exterior grade caulk.
redline is offline   Reply With Quote
Old 10-07-2007, 05:18 AM   #3
UV degrades the Faom............. you'll need to cover it with more of an Ashpalt or concrete type caulking to help protect that as well.
mdlbldrmatt135 is offline   Reply With Quote
Old 10-07-2007, 05:51 PM   #4
Recommendations
So, what do you recommend that Ido to fill this crease between the foundation and the driveway?
Old 10-07-2007, 08:48 PM   #5
If it's a wide gap, Use the foam then cover that with either Concrete or asphalt caulking to keep the UV rays from degrading the foam.
Old 10-07-2007, 10:15 PM   #6
thanks much bud
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 11:02 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 01:49 PM
Driveway Pitch handy man88 Building & Construction 6 09-11-2007 05:15 PM
