07-13-2011, 09:53 PM
#1
Driveway cracks
My 12-year old asphalt driveway has many cracks (see the attached files).
I tried to repair it last year by putting some crack filler material in the cracks.
How to repair it this year?
Is it beyond repair?
07-14-2011, 07:29 AM
#2
Driveway cracks
Can't tell if that is the asphalt or the coating that is cracking. Try scraping some off from a small area.
The Following User Says Thank You to Just Bill For This Useful Post:
07-14-2011, 07:40 PM
#3
Master General ReEngineer
Driveway cracks
Ayuh,... If the base is stable, another inch of blacktop overlay will probably get ya another 10 or 15 years outa it...
The Following User Says Thank You to Bondo For This Useful Post:
07-14-2011, 09:49 PM
#4
Driveway cracks
How to tell after scraping some off from a small area?
07-14-2011, 09:51 PM
#5
Driveway cracks
How to find out if the base is stable?
07-14-2011, 10:01 PM
#6
Driveway cracks
The asphalt looks flat. No ruts that result from cars sitting on the surface. No curling at the edges.
How often did you seal it?
Call in a few contractors and get their take on the situation.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
07-14-2011, 10:42 PM
#7
Driveway cracks
From the pics my son that's in the seal coating business said it looks like a
build up of sealer from driveways that are coated every year.
Driveways are coated every 2 years or more around here anyways.
The Following User Says Thank You to High Gear For This Useful Post:
07-15-2011, 06:38 AM
#8
Driveway cracks
It don't look settled, or failing...
If it stays that way year round, have it repaved...
07-15-2011, 07:27 AM
#9
Driveway cracks
How to repair it now?
Do I first fill the cracks with crack filler?
After at least one day, then I put on the driveway sealer in one direction.
After at least one day, then I put on the second layer of driveway sealer in a perpendicular direction so as to cover all the cracks.
I live in Ontario, Canada. Our winter has a lot of snow.
I put on the driveway sealer about every 2 years.
Is that a reasonable frequency?
07-15-2011, 07:35 AM
#10
Driveway cracks
too much sealer ( thickness ),,, rent a scarifier & resurface the driveway - next time you apply sealer, put in on thinner
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following User Says Thank You to itsreallyconc For This Useful Post:
07-15-2011, 08:07 AM
#11
Driveway cracks
The application brushes have a screed on one side. You brush on the sealer, then screed off the excess.
Ron
B. Franklin 1759
07-15-2011, 06:22 PM
#12
Driveway cracks
My son said he has never heard of someone using a scarifier to fix that issue (not saying it couldnt be done that way) but usually at that point a new drive is installed. He suggested contacting some local to your area to see what they suggest doing. Also he said that you can have someone come and sealcoat your driveway for about the same if not cheaper then the materials cost to buy to do it yourself (his company charges ~$.10/sqft for residential).
His company has a big tanker truck (500 gallon) that has the sealer mix (which has latex and sand in it) then they pump it on to the driveway and spread it out (from nearest to the house to the street) with a 3ft wide broom. He said they dont use a squeegee after brooming it on.
I just had my 4600sqft drive done by his company and it took their 3 man crew 30 minutes to weed eat all the edges, blow the driveway and apply the sealer. After that I will never do it myself again!
The Following 2 Users Say Thank You to High Gear For This Useful Post:
07-15-2011, 06:26 PM
#13
Driveway cracks
I don't see how removing a build up of sealer would equate to having a new driveway put in.
Ron
B. Franklin 1759
07-15-2011, 08:36 PM
#14
Driveway cracks
Should the build up of sealer be removed first before new sealer be applied?
07-15-2011, 09:20 PM
#15
Driveway cracks
See post#10
Ron
B. Franklin 1759
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
