Driveway, Concrete Or Asphalt? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2007, 09:40 PM   #1
weekend warrior
Rewards Points: 150
driveway, concrete or asphalt?
I'd just like to hear the pros and cons of both....
I've heard asphalt doesn't raise your property tax, is this true?
I assume asphalt is much cheaper than concrete but has to be resealed yearly?
johnny331 is offline   Reply With Quote
Old 06-19-2007, 09:52 PM   #2
I don't think either of those assumptions is quite right. Why wouldn't asphalt affect your tax assesment, if concrete does?
Things to consider:
Concrete is rigid, and won't flex if the ground moves. Concrete will crack. So the prep needs to be really good for a concrete driveway. In snowy areas, concrete driveways don't work well, because ground frost cracks them, and plow trucks rip them up.
Asphalt is super expensive now, due to high oil prices. So I don't know how they compare now.
Here's more info from a quick google search. http://landscaping.about.com/od/driv...rete_drive.htm
NateHanson is offline   Reply With Quote
Old 06-19-2007, 10:03 PM   #3
weekend warrior
Rewards Points: 150
I once read (somewhere?) that the asphalt (or was it that "chip 'n seal") wasn't considered permanent, so it didn't go on your evaluation...
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
Concrete driveway repair options monkey3605 Building & Construction 5 08-18-2006 03:15 PM
Painting an asphalt driveway surfitness Painting 4 08-24-2005 11:08 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
Concrete Driveway Mulligan Landscaping & Lawn Care 5 03-23-2004 11:03 PM
