Driveway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 12:48 PM   #1
driveway
Any suggestions to keep initial cost as low as possible and any type of substitutions for rebar or any part of my project
Gimwitag is offline   Reply With Quote
Old 09-19-2011, 01:17 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
I'm assuming from you description that you want to pour a new driveway?
Keep the cost low? Do all the work yourself.
The small amount of money you might save by cutting back on rebar or other materials will be quickly lost the moment you see the big cracks and realize that it has to be done over.
Concrete is one of those things that you only really get one shot at it....."Do Overs" are not pretty......
Just about anything you can do to lower cost is also going to lower the strength.....labor is about your only 'variable'. And if you don't have experience....then your pretty much SOL.
I have done two concrete projects now...first one was done by a contractor....this time around I hired the same day worker he used....saved me a couple of thousand and I got a better product.
The Following User Says Thank You to ddawg16 For This Useful Post:
jomama45 (09-19-2011)
re: replace asphalt driveway. best method?? gramps416 Building & Construction 12 05-24-2011 11:50 AM
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 03:42 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 07:07 PM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 05:19 PM
