Dripping Sound In Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2007, 04:38 PM   #1
Unhappy
Dripping sound in wall
Recently moved into a house that is about 8 years old. I'm finding what seems to be a dripping noise in the kitchen wall, and am having a hard time determining what it might be. There are no pipes along that wall, only a vent. I'd love to get some advice on what it might be as at this point I'm not even sure who to have come out to look at it. Any thoughts would be great!! Thanks!
jodgaz is offline   Reply With Quote
Old 04-17-2007, 04:51 PM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
By any chance is there a refridgerator with a water line running to it nearby? Like for a built-in ice maker or water filter? They can make a noise that sounds suspiciously like water dripping inside walls. Other than that, are there any water pipes above that wall?
J187 is offline   Reply With Quote
Old 04-17-2007, 08:05 PM   #3
Darylh's Avatar
Well if there is no water or drain pipes in that wall then it sounds like the leak is coming from the vent. Does the vent go through the roof?? If so then the vent cap on the roof is leaking. Call a roofer
Darylh is offline   Reply With Quote
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 04:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
