Drilling Through Metal Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 09:44 PM   #1
plus4dbu
plus4dbu's Avatar
Drilling through metal studs
What are some options for drilling holes in steel studs with finished walls? I install A/V systems and usually get called in after walls are closed up or completely finished. I often need to drill thru sideways to create pass-thru's for wiring, while leaving the sheetrock undisturbed. So, a hole punch is not an option. A Unibit works when I have access, but I usually need to reach too far inside the wall, so there isn't enough space to allow the drill far enough in. I've been using wood spade bits, but they get chewed up pretty quickly and that gets expensive. Is there a way to extend the Unibit? Are there any other tools I'm not aware of?
Thanks,
Mark
plus4dbu is offline   Reply With Quote
Old 01-23-2009, 05:52 AM   #2
I have only ever used a sharp bi metal hole saw. One problem in a closed wall is hot shavings dropping inside. If you use a dull one and it binds the drill's torque could put a hole in the wall . Another issue is that it can leave a sharp edged hole cut which can strip your insulation off the wire you feed through.
Are you drilling horizontally or vertically? I rarelly go horizontal in steel as I am feeding C VAC pipe.
Chemist1961 is offline   Reply With Quote
Old 01-23-2009, 05:55 AM   #3
Remodeling Contractor
At an electrical supply house you will find long flexible drill bits and drill bit extensions that can be used. They are used in conjunction with a tool that allows you to steer the bit into the center of the stud, which you will need. Now you can use one of the available long bits or any bit you find works on a long extension.
Old 01-23-2009, 06:56 PM   #4
Rewards Points: 392
Originally Posted by Chemist1961 View Post
.... Another issue is that it can leave a sharp edged hole cut which can strip your insulation...
Code requires that a bushing be installed which would prevent this.
rustyjames is offline   Reply With Quote
Old 01-24-2009, 07:37 AM   #5
Fish in armored cable
Old 01-24-2009, 10:28 AM   #6
Code
Rusty,
Bushings / Code... Good Point.
Where I am, in my line I don't think the same code applies for low voltage, etc.
Old 01-24-2009, 08:37 PM   #7
I've never done this, but have seen ABS water line run as conduit to protect low voltage wiring, that runs through metal studs. The pipe is pulled through, then fished with a vacuum cleaner!
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 08:23 AM
metal or wood studs? pwise Carpentry 7 01-21-2009 11:08 AM
Drilling into metal studs, do they flex? thubbard Building & Construction 5 01-15-2009 01:19 PM
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 09:12 AM
How difficult is it to learn to use metal studs? YerDugliness Building & Construction 7 08-18-2008 06:59 PM
