Drilling Through Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2007, 10:31 PM   #1
Drilling through concrete
I'm planning on drilling a 1/4 inch hole through the concrete foundation of my house. The foundation is about 8 inches thick. Is a hammer drill the best tool for the job?
I'd sure appreciate any info. Thanks.
Mike
mpiercewa is offline   Reply With Quote
Old 08-10-2007, 10:45 PM   #2
yummy mummy's Avatar
Rewards Points: 1,016
Yes, a hammer drill is what you need to drill through concrete.
yummy mummy is offline   Reply With Quote
Old 08-11-2007, 06:08 AM   #3
Agent 000
SecretSquirrel's Avatar
If you're looking to buy a drill, might I suggest a 1" SDS rotary hammer drill. It can triple up as a hammer drill, a small chipper (hammer mode), and a regular 1/2" rotary drill. There are a wide variety of SDS bits and chisels.
If this hole drilling thing is just a one shot deal then forget everything I said as this would be way overkill for your needs.
SecretSquirrel is offline   Reply With Quote
Old 08-11-2007, 08:40 AM   #4
Thanks for the advice.
Old 08-11-2007, 03:18 PM   #5
remodeling pro
You actually want a rotary hammer, not a hammer drill, especially for going through eight inches of cured concrete. Although the names are often used
synonomously, they are two completely different animals.
troubleseeker is offline   Reply With Quote
Old 10-09-2007, 06:43 PM   #6
Rewards Points: 150
I nice 1" SDS+ Rot Ham is a good compromise ....
I ahve the later version...the Dewalt D25314 that come with both heads ... SDS+ and straight shank .....great little tool...
Maybe it doesn't do any one thing great, but it hits all the bases....
I'd buy it again....
JGarth is offline   Reply With Quote
Old 10-10-2007, 07:16 PM   #7
Rent the drill
Consider renting a combo rotary hammer/drill. This way you can test drive one for thye day and decide if you actually need to own one. Otherwise,
you may regret purchasing one from another due to noise, weight, ease of changing bits etc.
RemodelMan is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 08:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
