-   -   drilling a support beam (http://www.diychatroom.com/f19/drilling-support-beam-793/)
sdmotor 07-10-2005 03:22 AM
I have a large beam (gluelam) that supports my upstairs that runs below the ceiling of my garage. On either end of the garage there is a large vertical beam that runs directly under the beam in the garage that is attahced to the beam that runs along the ceiling. It looks like the beam being drilled holds up the beam that runs along the ceiling. Is it okay to drill through it to run a gasline for a tankless water heater? The hole is about 1 - 1 1/4 " diameter. The beam looks like a 4X4 or 4X6 with 2X4's on either side of it. Thanks for the help....
Teetorbilt 07-12-2005 10:51 PM
When drilling any beam, go for the center and make as small a hole as required.
You need to really discriminate here and get some local help. The advice that you are asking for is beyond this or any other forum. It sounds as if you are dealing with supporting elements, this may require an engineers advise.
Sometimes ya just got to be there.
