Drilling Metal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 09:53 AM   #1
Rewards Points: 87
drilling metal
I recently purchased a new (huge) deck umbrella. The metal base only had 2 of thee 4 holes drilled to secure to the deck. When I tried to drill the 2 new holes, it could only make a dent in the metal.
Is there a special drill bit for drilling metal?
Thanks everyone!
momof2labs is offline   Reply With Quote
Old 04-07-2010, 10:04 AM   #2
jlhaslip's Avatar
Rewards Points: 1,440
no. any standard twist bit will work.
Punch a centre mark (dimple) so the bit doesn't wander on starting the hole.
Use a small bit to predrill, them the larger bit to finish.
Of course, sharp bits work best.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 04-07-2010, 11:21 AM   #3
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
the only thing special should be that you need a sharp bit.
Also don't go fast. in fact you should almost be able to see the drill turn and not just a blur.
Big N8 is offline   Reply With Quote
Old 04-07-2010, 11:23 AM   #4
they do have auger bits that are made for metal, they are made out of a stronger material than a wood bit, and are designed for easier starts in metal. You can use a regular bit though, which I would suggest, unless you frequently need to drill metal, there is no point in buying new bits.
lanemiller is offline   Reply With Quote
Old 04-07-2010, 11:45 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,... Exactly,... and a few drops of Oil while drilling will Keep it Sharp...
Bondo is online now   Reply With Quote
Old 04-07-2010, 12:34 PM   #6
Rewards Points: 81
A low RPM drill will make things a lot easier. If you never plan on drilling through steel again, it might not be worth it, but I got a $39 Harbor Freight low-RPM drill and I find I use it all the time now. Here it is punching a 1/2" hole through an inch-thick steel plate with a cheap Harbor Freight bit. No problem at all.
At higher RPMs, it's easy to ruin the bit -- even with oil -- and you often end up with essentially a heat-treated (hardened) dimple.
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Old 04-07-2010, 02:12 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I don't know what size hole you are attempting to drill but generally, using a small bit first is much easier than just trying to punch out a big ol' hole.
Old 04-07-2010, 05:55 PM   #8
Slow with a sharp bit as mentioned and if it's a stainless base your going to need a good bit rather than several cheap ones.
Shamus
Shamus is offline   Reply With Quote
Old 04-07-2010, 06:07 PM   #9
joed's Avatar
Rewards Points: 12,356
What is the base made of. Type of material being drilled and quality of drill bit both affect whether a hole can be drilled properly.
Old 04-07-2010, 06:33 PM   #10
a reason to buy new tool...nuff said
The older I get the better I was
Old 04-08-2010, 10:01 AM   #11
haha if i can buy new tools, i will. The only new thing I won't buy is a hammer, cuz I like mine too much
Tags
drill bit , metal drill bit
How to drill through metal in headers Docfxit General DIY Discussions 5 07-05-2009 10:31 PM
Drilling through metal studs plus4dbu Building & Construction 6 01-24-2009 08:37 PM
Drilling into metal studs, do they flex? thubbard Building & Construction 5 01-15-2009 01:19 PM
Lubricant for drilling in metal downunder General DIY Discussions 8 07-07-2008 06:52 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
