Drilling Into Steel Door All The Way Thru For Inside Security Bar Install - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 12:31 PM   #1
drilling into steel door all the way thru for inside security bar install
I need to drill (1/4") thru my steel door to install inside security bars-will my 12volt Ryobi work or should I get the electric drill out? And, do I start with a smaller drill bit size 1st and use oil to prevent overheating/
docjlb is offline   Reply With Quote
Old 12-18-2010, 04:47 PM   #2
Drywall contractor
Rewards Points: 1,070
If it's a residential, exterior "steel" insulated door you will have no problem drilling. It's just a metal "skin on the door, not solid steel. Even a commercial exterior door isn't (normally) solid which is the only reason you would need to use oil while drilling....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-18-2010, 04:52 PM   #3
Rewards Points: 5,336
Use a sharp bit and use a punch to dimple the exact spot you want the hole. By using the punch it keeps the bit from wandering.
Keep the bit perpendicular to the door or the holes won't line up.
The ryobi should be fine with a good battery.
Ron
Old 12-18-2010, 05:28 PM   #4
Drywall contractor
Good call on the center punch!
Old 12-18-2010, 05:48 PM   #5
These doors are foam filled and the bolt head will dent the exterior. Drill the hole a little larger and insert a short piece of steel pipe over the part of the bolt that is inside the door. When you crank on the nut to tighten it, it won't dent the door.
mrgins is offline   Reply With Quote
How to install wood screen door and exterior steel door orange Remodeling 2 07-16-2010 01:00 PM
How to install a wireless security camera BIO Electrical 7 03-23-2009 10:59 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Security Light install on metal outbuilding Chevyscrounger Electrical 7 01-01-2009 04:13 PM
