Old 01-04-2008, 04:10 PM   #1
Drilling into metal studs, do they flex?
I'm working on mounting two LCD tv's at the office. After doing a little research it seems that drilling into the metal studs and using toggle bolts should do the trick. My boss is concerned that when we drill into the stud, it will flex to the point of damaging it or the wall.
Is there any truth to this? I really didn't think it would be a problem.
Thanks a lot!
thubbard is offline   Reply With Quote
Old 01-04-2008, 04:22 PM   #2
Use a sharp drill for drilling into metal.
redline is offline   Reply With Quote
Old 01-04-2008, 10:38 PM   #3
ICF Construction
Use self tapping screws...designed for steel studs
Chris
Chris Johnson is offline   Reply With Quote
Old 01-05-2008, 12:12 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
...good advice.
Does steel framing flex? YES.
As advised, use self-tapping fasteners to avoid this.
- Build Well -
Old 01-14-2009, 04:18 PM   #5
plus4dbu
plus4dbu's Avatar
Yes, you could use self-tapping fasteners, but I prefer drilling holes through the sheetrock and steel stud, then using Hilti 1/4-20 Togglers. Here's a link:
http://www.homedepot.com/webapp/wcs/...egoryID=500218
The problems I have with using self-tapping screws for mounting TVs on walls with sheetrock and steel studs are 1) it is easy to over-tighten (or under-tighten) and therefore not get a good solid hold and 2) since steel studs CAN flex you sometimes can't tell whether you've actually gotten the screw to tap the stud instead of pushing it away and 3) since you aren't drilling a hole you can't see if you've damaged audio/video/electrical lines inside the wall.
I use a good 1/2" drill bit or Unibit to drill a clean hole thru the rock and stud, and then insert the toggler. Proceed very cautiously and drill a small pilot hole first, if needed, to minimize risk of damaging audio/video/electrical/alarm/phone/plumbing/who knows what. Once you've finished the hole, you can look in it, or carefully put a finger or fish tape in it, and confirm that you've got a good area for a toggler and that nothing in the wall has been damaged. Also, make sure you have enough space inside the wall to insert the toggler and to tighten the screw all the way down.
plus4dbu is offline   Reply With Quote
Old 01-15-2009, 02:19 PM   #6
If the studs are heavier gauge (20-16) self drillers would probably be fine as long as what you're hanging isn't very heavy. But if the studs are the light ones used for partitions then I'd go with the toggle's. Try drilling a small hole to test the thickness of the material.
rustyjames is offline   Reply With Quote
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 09:23 AM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 03:30 PM
metal studs to build up attic floor Airborne180 Carpentry 6 12-13-2006 05:02 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 05:31 PM
