Drilling Into A Concrete Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 11:16 AM   #1
Drilling into a concrete wall
My top tip for drilling into a concrete wall is to use a plastic bag with a strip of mastic tape to one open mouth side of the bag. Then stick the bag to the wall under the spot you are about drill this will leave both hands free and catch all that messy dust.
What do you think?
Brendan20jb is offline   Reply With Quote
Old 01-07-2012, 11:56 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I guess so
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-07-2012, 12:00 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Brendan20jb View Post
Then stick the bag to the wall under the spot you are about drill...
What do you think?
The bag sounds too flexible.
Cut an old rubber ball in half.
Bigger hole? Use a bigger ball.
Greenlee and some others sell variations; here's one:
Old 01-07-2012, 12:03 PM   #4
Rewards Points: 13,960
30 sec. with a shop vac or running it and holding the hose under the drill works fine for me.
woodworkbykirk (01-07-2012)
Old 01-07-2012, 12:07 PM   #5
Disabled wood vet
titanoman's Avatar
Alrighty then.
Old 01-07-2012, 12:24 PM   #6
Drilling hole over head use a paper cup, working on the wall to catch the dust.
Hardway is offline   Reply With Quote
Old 01-07-2012, 12:39 PM   #7
MarginallyQualified
Agreed; and thinking such = my brainfart above. oi
Old 01-07-2012, 05:10 PM   #8
Disabled wood vet
titanoman's Avatar
Another good strategy.
Old 01-07-2012, 08:29 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
im with joe on this, works like a charm and is the expected method when drilling into old concrete and plaster walls on a government building as to control risk of asbestos becoming airborn
woodworkbykirk is offline   Reply With Quote
Old 01-08-2012, 03:34 PM   #10
Mold!! Let's kill it!
Rewards Points: 2,012
Put some shaving cream in the cup to trap the dust.
Old 01-08-2012, 06:57 PM   #11
drilling a hole in concrete
The bag works very well the prob with the vac is you have one hand on it and the other on the drill. How do you blow your noise or scrach your ass if needs be????????
Old 01-08-2012, 07:04 PM   #12
brendan20jb
I agree when drilling over head the cup works very well. When drilling a concrete wall you should be using an SDS drill no big cloud of dust from that and the dust drops into the bag. Why would anyone mix asbestosis into concrete??
Old 01-09-2012, 11:39 AM   #13
SDS drill = Hammer drill
I agree dust drops
Old 01-09-2012, 03:08 PM   #14
Gymschu's Avatar
Rewards Points: 930
I hate when I have to blow my "noise."
Old 01-09-2012, 06:19 PM   #15
Asbestos was added to concrete and other concrete-like products as an enhancement to strength. Asbestos-containing cement products generally contained Portland cement, aggregate and chrysotile fibers. The asbestos content of the product varied up to 50 percent by weight depending on the use of the fiber.
These asbestos cement products were used as siding and roofing shingles, wallboard, corrugated and flat sheets for roofing, cladding, partitions and even as pipes. The raw material for all of these products begins as a powder that is mixed by a mixing operator to the correct proportions.
Read more: http://www.mesothelioma.com/asbestos-exposure/occupations/mixing-operators.htm#ixzz1j0fdOcqf
Exterior wall on concrete pad - waterproofing under wall? (Illustration included) JustADoc Building & Construction 12 08-18-2011 05:07 PM
Seal Siding to Concrete Wall? stevex Building & Construction 3 08-07-2011 06:46 AM
A glue that works on precast concrete wall wildwings Building & Construction 5 12-30-2010 08:34 AM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
